Raph31 Posted May 12, 2009 Report Posted May 12, 2009 Hello, I have created severals typedefs (mainly clusters), and I want to know how to get the path of the typedef from a refnum control of one of this typedef ? This is a kinf of how to get typedef name at run time. I just want the path because depending this path I will choose VIs to execute. I hope this is clear. Thanks for your help. Quote
Dan DeFriese Posted May 12, 2009 Report Posted May 12, 2009 QUOTE (Raph31 @ May 11 2009, 10:37 AM) Hello,I have created severals typedefs (mainly clusters), and I want to know how to get the path of the typedef from a refnum control of one of this typedef ? This is a kinf of how to get typedef name at run time. I just want the path because depending this path I will choose VIs to execute. I hope this is clear. Thanks for your help. This may not be wise. This path information is only useful during devepment and would be stripped out when build an executable. I think the better approach would be to create a polymophic function that is selected based on the datatype. Quote
