ritesh024 Posted May 22, 2009 Report Posted May 22, 2009 Dear all, I am in a bit confusion in choosing between XY Graph and Waveform Graph to plot my data. Here is the Scenario: i am receiving data for 24 channels(400 samples each) from my H/W. so the X scale of the Graph is 0-399. Now once i have captured all the data, i might want to change the Sweep speed of a particular waveform. Sweep is like Zooming in or Zooming out. Say if i captured the data at sweep speed = 2. Now i want to view it at 4, means, i want to Zoom Out. Now that means that i want to view my 400 samples on First 200 samples of the Graph. If earlier the X difference b/w points was 1. not it'll be 0.5. Waveform Graph has the property wherein i can make a cluster of Initial X, delta x and the waveform. Problem is it'll take delta x for all the plots on the graph and wont work if i want to change delta x of just 1 plot. In XY Graph, i can give X and Y values for independent plots. So, it can workout my problem. But giving X and Y values is a bit tedious job. I want to know is there any way i can use Waveform Graph to plot my data and can change sweep speed of just 1 plot without doing much of coding, or is XY Graph the only solution to my Problem ?? Ritesh Quote
candidus Posted May 22, 2009 Report Posted May 22, 2009 Hallo, you could try to set the parameters for a particular waveform before you plot it instead of setting properties of the waveform graph. Unfortunately I don't have LV here at the moment so I can't verify whether this works. Quote
