DAQ problem
Hi! I am a PCI-6602 user, I have some trouble using the VI file provided by the DAQ-traditional.
I opened the VI "CTR Pulse Config.vi", and input the parameters as seen in the attachment:
I am using LabView 7.0.
My problem is, if I input a number greater than 16777215, then it will show error 10137 -- invalid period.
Could anyone explain to me why this happens?
I am asking this, because I want to make a pulse with longer pulse width.
Many thanks!!
Your error is exactly 24 bit. Either hardware or driver problem.
Felix
PS: I didn't manage to get that calculated with win calc. I had to use LV for that. Geeky, isn't it.
Edit: Checked hardware docs, it's 32 bit. So try DAQmx drivers instead of traditional DAQ.
