finimits Posted June 10, 2009 Report Posted June 10, 2009 Hello Everyone, I would like to know if anyone has converted a simulink model into a dll using the SIT(simulation interface toolkit) and then called the .dll from a LabView vi WITHOUT running the dll on a real-time target i.e. just your PC. ? I'm not concerned about real-time operation on a hardware, all I want to do is to call a .dll built from simulink and have it be controlled by a Labview front panel. Any help would be greatly appreciated! Have a wonderful day. finimits. Quote
Mellroth Posted June 12, 2009 Report Posted June 12, 2009 QUOTE (finimits @ Jun 9 2009, 04:46 PM) ...I would like to know if anyone has converted a simulink model into a dll using the SIT(simulation interface toolkit) and then called the .dll from a LabView vi WITHOUT running the dll on a real-time target i.e. just your PC. ?... Sure, just use the methods from the "Model interface" palette to interface the model dll. /J Quote
xyl4804 Posted May 15, 2010 Report Posted May 15, 2010 QUOTE (finimits @ Jun 9 2009, 04:46 PM) Sure, just use the methods from the "Model interface" palette to interface the model dll. /J Hi, could you give us some more details about this methods, or a example Quote
