Karissap Posted July 3, 2009 Report Posted July 3, 2009 Name: USB Continuous Acquire Submitter: LAVA 1.0 Content Submitted: 03 Jul 2009 Category: Machine Vision & Imaging LabVIEW Version: 8.0 Version: 1.0.2 License Type: BSD (Most common) Potentially make this available on the VI Package Network?: Undecided Copyright © 2007, Karissa Purcell All rights reserved. Author: Karissa Purcell --see readme file for contact information Description: This VI uses the NI-IMAQ for USB drivers to continously acquire an IMAQ image. The USB camera is selected from a list generated from the "IMAQ USB enumerate cameras" vi. Grab rate is controlled using an event structure. This is so that image processing routines can use other event cases. *Tested with a Logitech QuickCam IM Dependancies: Labview 8.0.x or higher IMAQ drivers NI-IMAQ for USB drivers (http://web.archive.org/web/20071124171708/http://sine.ni.com/devzone/cda/epd/p/id/5030) Change Log: 1.0.2: Changed error cluster wiring 1.0.1: Fixed list control to select camera, improved error control. 1.0.0: Initial release of the code. Click here to download this file Quote
