Chris Davis Posted July 3, 2009 Report Posted July 3, 2009 Name: Example - Create Polymorphic VI Submitter: LAVA 1.0 Content Submitted: 03 Jul 2009 Category: VI Scripting LabVIEW Version: 7.1 Version: 1.2.0 License Type: BSD (Most common) Potentially make this available on the VI Package Network?: Yes Copyright © 2006, Chris Davis All rights reserved. Author: Chris Davis --see readme text for contact information Description:: This VI uses scripting to create a new polymorphic VI that contains the methods for creating any type of numeric control on a VI's diagram. This VI is designed to help a newbie learn some of the basics of LabView scripting. As well as serve as a tool to make scripting easier to code. Code was created and tested using LV 7.1.1 Code should work in higher LabView versions, but has not been tested there. Version History: 1.2.0: Added code to make polymorphic VI's icons match thier intended numeric type. Fixed a bug where an error 7 would occur because the polymorphic VI doesn't exist on the users machine to be deleted. 1.1.0: Re-release of code as LV 7.0 for more universal compatability. Changed code slightly to read empty polymorphic VI from disk, instead of using a constant on the diagram. 1.0.0: Initial release of the code. Click here to download this file Quote
