Shared Var Control binding change at runtime
Hi all,
I'm working around a new project where I have to control more than one cRIO all with the same application on it.
What I'm trying to do is to use a network published shared variables set to control each cRIO from a common HMI deployed on 1 or more PC.
What I would like to know is if it's possible, after having bounded a shared variable to a control or indicator, to change at runtime the binding path so to use the same control or indicator
to control a predefined cRIO using for example a case to select which in use.
I found this document http://digital.ni.com/public.nsf/allkb/2E8BAD0EA218A7558625712E0003F044 and, after some test (I'm in the case "without DCS"), I realized that on a cRIO this is not possible with this method.
Thanks in advance for every suggestion.
Pipeolo
