JohnRH Posted June 19, 2003 Report Posted June 19, 2003 The following seems to lead to nasty errors and finally a complete LabVIEW crash. 1) drop down a 3D gauge control 2) right click gauge, select "Properties", and Add two more Needles (so the gauge now has 3 needles). 3) click OK It appears that this bug shows up on any numeric control which you can add multiple pointers to. The work around is to add one pointer at a time, either in the properties page, or by right clicking on the control and selecting "add needle...". Quote
Michael Aivaliotis Posted April 9, 2004 Report Posted April 9, 2004 Ni has a fix for this: Solution: You can resolve this problem in the following ways: * Replace the ControlPropertyPages.llb in the labview\resource\PropertyPages directory with the attached file. * Add a needle or slider by right-clicking the control and selecting Add Needle or Add Slider from the shortcut menu. * Add or delete only one needle or slider at a time and close the Properties dialog box between each change. I've attached the link: Insane Object Errors When Adding or Removing Needles or Sliders in Properties Dialog Box Quote
