Olivier Jourdan Posted July 25, 2009 Report Posted July 25, 2009 Name: Capacity indicator Submitter: odjau Submitted: 02 Jul 2009 Category: X-Controls LabVIEW Version: 8.2 Version: 2.0.3 License Type: BSD (Most common) Make this available on the VI Package Network?: Undecided Copyright © 2007 SAPHIR (Olivier JOURDAN) All rights reserved. Author Olivier JOURDAN --see readme file for contact information Description Use capacity indicator to provide information about the level or amount of something that has well defined minimum and maximum values. For example, you might use a capacity indicator to showthe current level of storage-space usage on a server or the charge left in a battery. Features * Usefull interface to set properties (colors and threshold) * All settings are modifiable by property * Refresh value of capacity indicator with percent of disk used by method Instructions Just unzip the code into any folder of your choice and select the file "CapacityIndicator.xctl" as a control. This code has been tested to run under LabVIEW 8.2.1 Dependancies None Change Log * 2.0.3 : Change to BSD Licence * 2.0.2 : Added comments and documentation - Fixed initialisation bug * 2.0.1 : Initial submission to LAVA CR. Click here to download this file Quote
