Cyclic data exchange between cRIO and S7
I want to exchange data between a CompactRIO (stand-alone) and a PLC (S7-300 with CP343-1) via native TCP/IP sockets
- control data: S7-Send -> cRIO-Receive
- measurement data: cRIO-Send -> S7-Receive
The send and receive is independent to each other and should be asynchronous.
I don't (want to) use OPC. May be, it is also not possible due to VxWorks-OS.
Now I have some questions concerning the programming
1. Can I use only one socket for send/receive (either client or server)?
If yes, should I exchange data sequently in one loop (client: send-receive or server: receive-send) or "parallel" in two loops (send and receive separately)?
2. Is it better (or even necessary) to use two separate connections for my purpose (client-send and server-receive)?
I'm not very familiar with S7, but I heard it is easy to project either one or two connections.
Thanks in advance!
Edited by MichaDu
