zythum Posted August 10, 2009 Report Posted August 10, 2009 (edited) Hi, On a setup, we using a touch screen. The LabView Software is running on full screen. I need to deactivage my front panel if the screensaver is on to prevent user start anyting. I use SystemParametersInfoA from user32.dll and this is working good, except, if I quit the software. "myexe a fin a error and need to close" (someting like that, my XP is in french). I don't have issues in debug mode, this error happen in exe mode. I use LV 8.6.1. Do you have any idea why? Thank you test.zip Edited August 10, 2009 by zythum Quote
zythum Posted August 10, 2009 Author Report Posted August 10, 2009 I forget, the error happen when I close the front panel. Hi, On a setup, we using a touch screen. The LabView Software is running on full screen. I need to deactivage my front panel if the screensaver is on to prevent user start anyting. I use SystemParametersInfoA from user32.dll and this is working good, except, if I quit the software. "myexe a fin a error and need to close" (someting like that, my XP is in french). I don't have issues in debug mode, this error happen in exe mode. I use LV 8.6.1. Do you have any idea why? Thank you Quote
zythum Posted August 11, 2009 Author Report Posted August 11, 2009 I forget, the error happen when I close the front panel. Problem fix. Changing the Uint8 to Uint32 and changing the path from C:\Windows\System32\user32.dll ti user32.dll Thank Quote
