Error from SPT VIs in LV 2009
I discovered a problem with legacy 8.6.1 code when I upgraded to LV 2009. The code involved the Easy Discrete Gabor Transform.VI. Regardless of parameter set used, the VI returned error -42619. After some investigation it was determined that the source of the error was Fast Dual.VI and the reason for the error turned out to be that the configuration of the Call LIbrary Function Node had been changed in LV 2009. The AE created a new Call Library Function Node, configuring it the same as in 8.6.1, and voila, no more error.
CAR #182427 was filed to address the change in the Easy Discrete Gabor Transform so R&D will investigate it further.
