GSR Posted August 19, 2009 Report Posted August 19, 2009 If I have an equation y(t) = a1x1(t) +....+a9x9(t)+nonlinear factor+noise want to do linear regression any different between sample rate is 100Hz and 1000Hz? Assume 100>>nyquist frequency Will the fitting be better at 100Hz because of the variable to sample rate ratio is higher at 100Hz?? BTW, what is this icon mean:ph34r: <========???? Quote
