kristos_b Posted September 23, 2009 Report Posted September 23, 2009 Hi all, I have a question about one of ni usb modules. Previously I was using usb6009 and because it has low ADC input impedance (144k) I was forced to use external buffers and some other circuitry. Now I have in the Lab the usb6212 module which has ADC input impedance 10GOhm when the device is on and 1200 Ohm when it is off (according to this http://www.ni.com/pdf/manuals/371932f.pdf). This is perfect for my application because I have to measure the line first and after measurement I have to short the capacitor to get ride the charge (continuously in the loop). My question is how you actually switch between high and low input impedance. I tried different things from DAQmx palette but nothing works for me. I could not find anything about this problem on ni webpage or LAVA. Could you help me with this or point me to the solution on the web. Thanks, Krystian Quote
kristos_b Posted September 24, 2009 Author Report Posted September 24, 2009 I got the reply from customer support: "The 1200 ohm off impedance is the input impendance when the device is unplugged from the PC and powered down, there are no options toprogrammatically switch to this impedance." No switching of the input impedance unfortunately... Quote
