JackHamilton Posted January 10, 2004 Report Posted January 10, 2004 :headbang: One could split hairs that this is not a bug. But one would expect that you could programmatically with the property node settings: "Symbols enabled" = True and "Active Cell" set to a column other than 1 you should be able to generate a symbol of choice in any column and row location of a Multi-column listbox. This is not the case - no symbol shows up at all when attempted programtically into a column other than column 1. Only column 1 supports symbols. Also as Mike A. Pointed out - a symbol will only appear IF text is present in the cell. Even if it's a space. Of course none of this is documented in the help. :thumbdown: Quote
