Carlos Colombia Posted November 12, 2009 Report Posted November 12, 2009 Hi, this is the first time I use MatLab script node in LabView. I am using it because I have a MatLab speech recognition algorithm that I want to use with Labview for control. 1- If my Matlab code requires the user to press a key when the user is ready to say a command, will I be able to press this key in Labview? or read data displayed in the Matlab command window? such as fprintf, pause commands etc?. I ask this question because the Matlab command window from LabVIEW doesn't show the MatLab code. 2- If my code requires several .m files. Do I have to include just the toplevel file ? or also generate Matlab script nodes for all the files called? If this is the case, how do I chose the order of compilation for all these MatLab script nodes. I would really appreciate your help, Carlos Quote
mostafanfs Posted April 23, 2010 Report Posted April 23, 2010 Hi guy ... Could you share your MatLab speech recognition algorithm ?? Tnx Quote
