GSR Posted November 12, 2009 Report Posted November 12, 2009 I know there are channel A, B (maybe also Z) in a regular optical encoder. I just have a encoder card which say it is for Phase A+, A- , B+, B-. I guess Phase A = Channel A, but what is the + and - mean??? Quote
crelf Posted November 12, 2009 Report Posted November 12, 2009 I know there are channel A, B (maybe also Z) in a regular optical encoder. I just have a encoder card which say it is for Phase A+, A- , B+, B-. I guess Phase A = Channel A, but what is the + and - mean??? The channels are usually isolated differential so the + is the positive side and - is the negative side of the signal. Quote
EricLarsen Posted November 12, 2009 Report Posted November 12, 2009 The channels are usually isolated differential so the + is the positive side and - is the negative side of the signal. Most encoders are differential and will be labeled A+, A-, B+, B-. Some encoders are single ended and are usually labeled A, B, and Gnd (or something like that). In that case, you would hook A to A+, B to B+, and Gnd to both A- and B-. If you truly have a single ended encoder, you might check with the manufacturer to see how they recommend hook up. Disclaimer: Hooking single ended encoders into differential inputs doesn't always work and is usually not recommend by the encoder card manufacturer. But I've done it a few times and it's never burst into flames. Quote
crelf Posted November 12, 2009 Report Posted November 12, 2009 In that case, you would hook A to A+, B to B+, and Gnd to both A- and B-. Right, and the same goes for the Z+ and Z- if you care about absolute measurements. Quote
Daryl Posted November 13, 2009 Report Posted November 13, 2009 I know there are channel A, B (maybe also Z) in a regular optical encoder. I just have a encoder card which say it is for Phase A+, A- , B+, B-. I guess Phase A = Channel A, but what is the + and - mean??? In addition to all the great responses so far, if you are using an optical encoder in a high vibration environment, you may need to put a filter on it if you get some bleed through on channels A and B. Quote
EricLarsen Posted November 13, 2009 Report Posted November 13, 2009 if you are using an optical encoder in a high vibration environment, you may need to put a filter on it if you get some bleed through on channels A and B. Just out of curiosity, what kinds of filters have you found to be effective for this? I've had this problem before and never really came up with a satisfactory solution. Quote
Daryl Posted November 19, 2009 Report Posted November 19, 2009 Just out of curiosity, what kinds of filters have you found to be effective for this? I've had this problem before and never really came up with a satisfactory solution. I'll have to check if I have any left and get back to you. Its been a while since I have had to deal with this so I cant remember off the top of my head. All I remember is I used something in a 8 pin DIP configuration that seemed to work well. Quote
