Spiderman156 Posted November 20, 2009 Report Share Posted November 20, 2009 Hi, I am trying to set up a stepper motor to run with labview 8.2. I am pretty sure that the code I have written should work so I am trying to figure out if I have wired everything correctly, I hope this is the right place for this. I have added the description and manual for the SMC EMY2 stepper motor (page 22 is where I am looking mainly for the wiring, I am using the 5-point Stoppable Type) and manuals for the two NI DAQs I am using, NI9474 for the control singals to the motor and NI9423 for receiving signals from the motor. I am using an external power supply with these that is set to 24V. I have the NI 9474 in slot 5 of the cDAQ-9172 and the NI 9423 in slot 6. I have attached to the power supply cable wires wires as described in the EMY2 manual to the power supply and the motor runs fine when using the attached controller, then I have attached the I/O wires as follows: Brown - Vsup of the NI 9474 Blue - Com of the NI 9474 Pink - line 0 of the NI 9423 Orange - line 1 of the NI 9423 Yellow - line 2 of the NI 9423 Red - line 3 of the NI 9423 Green - line 4 of the NI 9423 Purple - line 3 of the NI 9474 Gray - line 7 of the NI 9474 Black - not attached White - line 2 of the NI 9474 I can get the NI 9474 to output a signal but the stepper motor does not seem to react at all. I had a colleague recommend that I connect the - terminal of the power supply to the ground terminal, is that a good idea. If anyone can think of something to help that would be great and if you need more information just ask and I'll try to get it. Thanks. Stepper Motor Manual.pdf NI 9474 Operating Instructions.pdf NI 9423 Operating Instructions.pdf Quote Link to comment
