George Pollock Posted November 24, 2009 Report Posted November 24, 2009 I'm using LV 8.6 and Compact Field Point I/O. I use an AI-110 for analog measurements. It would be great to be able to change the measurement scale of the AI-110 from within the running LV app. As an example, try to make a cheap $20 multimeter, the sort you get at the local electronics outlet. If you make a measurement and don't like how it fits the scale, you just turn the knob, select a different scale and get the measurement you want. All this would work in LV except that I find no way to get out to the AI-110 and change its scaling. Doing it one time once, forever, with MAX is not what I am looking for here. I must be overlooking something here. Any help appreciated. Quote
