jnew8916 Posted January 7, 2010 Report Share Posted January 7, 2010 I am using a piece of cDAQ hardware to acquire voltage outputs from 16 transducers measuring pressure in a wind tunnel. Each slot in the cDAQ can accommodate 2 transducers. I am able to calibrate one slot at a time using DAQ assistant, but I would like to be able to calibrate all 8 of the required slots simultaneously. Could someone please advise me on the easiest way to attempt this? Many thanks for any help. Link to comment
jnew8916 Posted January 11, 2010 Author Report Share Posted January 11, 2010 I am a very new labview user, after learning a little more about the DAQ system I am using I realise my initial post is probably lacking some detail. I am using a PXI-1044 chassis with 8 PXI-6224 modules inserted. Each module can take 2 transducers which are converting pressure readings into an analog output. I would like to be able to calibrate all of the transducers going into all of the modules simultaneously. Link to comment
Please sign in to comment
Sign In Now
