Wim Posted January 8, 2010 Report Posted January 8, 2010 Hi Lava, I've a problem with my xcontrol and hope you can help me. My X-control is an array combined with a few buttons. I want to use the mouse scroll wheel to scroll through the array. I've made a 'Thread' that runs parallel and generates a user event when the user is scrolling. (Thread: while loop that polls the 'acquire data from device (=mouse)) I even detect if the mouse is on the xcontrol or not (mouse enter, mouse leave events in facade.vi) When i open the FP of my Thread it does what it should be doing. Boolean is true when mouse is on array ... false when it leaves and I get the scroll value from the mouse. But .... I was hoping that LV will run the facade.vi when a user event is generated but it doesn't ... it builds a buffer and when another event is called in the facade, my array starts dancing (buffer of user events) What I do: - create user event in init.vi - register for events: first call of display state change in facade.vi - generate user events in parallel thread (detect scrolling) Sorry but i cannot attach the LV-code because of company policy. I hope my problem is clear and that someone can give me some tips. Thanks in advance. Wim Quote
Wim Posted January 8, 2010 Author Report Posted January 8, 2010 All, i have a work arround. ( Thx to my boss ) Now I take a reference to a 'scroll control' in my thread and I write through a prop node val(sgnl) to get a value change event in the facade. However ... info on using user events is appreciated Quote
candidus Posted January 21, 2010 Report Posted January 21, 2010 I had exactly the same problem... I wanted to send an event to a group of XControls. I also had the idea tried to send a Value(sgnl) to my XControls to wake them up, but these events were also forwarded to my toplevel event handler: It was flooded with events and caused the frontpanel to freeze... So I ended up in not using custom events for this task. There are many things you can do with a control when you have its control refnum without the need of sending events. For my XControl I had just to store the refnum to the main control on the Facade FP and use it later for setting properties. Perhaps you can try a similar trick. Quote
