newLVuser Posted January 13, 2010 Report Posted January 13, 2010 Hi, Is it possible to reset the counters to Zero of my code by using a button? thanks in advance Quote
Gary Rubin Posted January 13, 2010 Report Posted January 13, 2010 (edited) Hi, Is it possible to reset the counters to Zero of my code by using a button? thanks in advance Add another selector (the thing you're using to decide whether to increment your pass counter) to each counter wire, and use the selectors with the reset button to determine whether to feed the wire contents or a '0' into the shift registers on the right side. Edited January 13, 2010 by Gary Rubin Quote
newLVuser Posted January 14, 2010 Author Report Posted January 14, 2010 Add another selector (the thing you're using to decide whether to increment your pass counter) to each counter wire, and use the selectors with the reset button to determine whether to feed the wire contents or a '0' into the shift registers on the right side. Thank you for replying Quote
