Organising an array
I currently have an output array which is the product of 3 input channels (lets call them a, b and c.) The output array produces the data so that it is in the order a1 b1 c1 a2 b2 c2......an bn cn. I need to organise this data so that it is split into three arrays, one for each channel, with the data in chronological order, i.e. a1 a2 .....an. I also need the process to be dynamic enough that it can cope with the number of channels changing each time the program is run. I am sure there must be an easy enough solution to this problem I am just not experienced enough to know what it is. Any help would be great.
Adding output arrays dynamically is not possible [to my knowledge] - so either go for 2D array [ if uniform data size] or, 1D array of cluster where each cluster contains an array as the output data format. A simple logic can parse the data into any of these output format. Hope this helps!
If you have a fixed number of channels, you could use the decimate array function.
For dynamic size of channels, you would need to use a 2D array (clusters are also static).
If you have 1D data, you could try with the reshape array function if you get a 2D array with the right order. Otherwise you will need to do it by coding on your own... (for-loop or nested for-loops)
Felix
