Ed Dickens Posted April 13, 2004 Report Posted April 13, 2004 I've just run across a possible bug in the Build Text Express VI. Drop the VI and at first configure an input to accept a numeric by selecting Number under the Variables Properties section, and check the Quote
Michael Aivaliotis Posted April 13, 2004 Report Posted April 13, 2004 Yes, I can reproduce this. Also, if you break the express VI you will see that NI doesn't replace the complete string variable. See attached image. Quote
Ed Dickens Posted April 13, 2004 Author Report Posted April 13, 2004 I also sent this to NI support and it's a known issue that should be fixed in 7.1. The current workaround is to do what I described above. Ed Quote
