Ed Dickens Posted May 12, 2004 Report Posted May 12, 2004 While checking to see if the 7.0 bug I found with this VI was fixed in 7.1, I ran across an odd behavior that wasn't there in 7.0. (That bug was fixed) When configuring the VI, if you select either Number or Boolean in the Variable Properties before typing anything the Text with Variables box, the first character you type will switch the Variable Properties back to Text. Subsequent variables entered will not change the Variable Properties back to Text. I don Quote
