Berthil Posted April 9, 2010 Report Share Posted April 9, 2010 When I'm opening a vi with a visa resource name control on the frontpanel Labview crashes. Does anybody have the same problem? It is easy to check, take a blank vi put "Visa Configure Serial Port.vi" and create a control on the vias resource name or try to open "Visa Configure Serial Port.vi" Greetings Berthil Link to comment
John Lokanis Posted April 9, 2010 Report Share Posted April 9, 2010 No problem here. Must be your machine. Link to comment
asbo Posted April 9, 2010 Report Share Posted April 9, 2010 No crash here either. Try poking around in MAX (maybe export what you have and then wipe the slate clean) and see if that provides any enlightenment. Link to comment
Berthil Posted April 16, 2010 Author Report Share Posted April 16, 2010 (edited) Thanx for triing. The problem is solved with help from NI. I upgraded labview2009 to labview2009SP1, but I didn't install the newest drivers. The NiVisa 4.5.1 was causing the problem. Even MAX was giving problems and wasn't showing the ports on my computers. I upgraded the NiVisa driver to 4.6.2 and cleaned the corrupted MAX database and the problem was solved on the computers where I had the problem. Edited April 16, 2010 by Berthil Link to comment
Please sign in to comment
Sign In Now
