Export/Import Strings
I have an application, that will run in different languages. I thougth of using "Import Strings" from the Tool>Advanced menu.
Now the problem I have is that different controls are cluters and/or arrays of strings. These strings contain default text as e.g. pop-up text. When I want to import a "translated" XML-file, only the content of the first element of these cluster/array is changed. All the other elements keep their original text.
I use LV6.1! Is this a bug and solved in LV7?? Is there a solution/workaround?
Didier
