Align a fp object relative to the pane?
Hello,
I have a front panel graph which I've set to resize as the front panel is resized. This works perfectly.
I then have a string indicator which I use to give the graph a title, I update this each time a file is loaded for analysis.
I'd like to be able to fix the alignment of the string so that it stays at the top-centre of the graph as it is resized. If I group the title and graph then the string box itself is scaled which I don't want.
Is this possible please?
Thanks,
Martin
Hmmm, it seems to be working now.
I was just about to change it so that when the window is resized an event gets the new width/height and re-sets the position of the indicator appropriately.
