spaghetti_developer Posted June 30, 2010 Report Share Posted June 30, 2010 Hi All, Does anyone know how access to the controls of a labview application (exe) from an external VI, using the VI-Server technique? Link to comment
Dan DeFriese Posted June 30, 2010 Report Share Posted June 30, 2010 Try reading this thread: http://lavag.org/topic/9007-vi-server-with-built-applications/page__p__53908__hl__defriese__fromsearch__1#entry53908 Link to comment
spaghetti_developer Posted July 1, 2010 Author Report Share Posted July 1, 2010 Hi Dan, thank you for your suggestion, I followed the instruction that are described in that topic but unfortunately it still doesn't work. I can't understand where I'm making mistake. Do you know if there is any other document that describe what I have to do to control the application exe with an external VI? Link to comment
Dan DeFriese Posted July 1, 2010 Report Share Posted July 1, 2010 Hi Dan, thank you for your suggestion, I followed the instruction that are described in that topic but unfortunately it still doesn't work. I can't understand where I'm making mistake. Do you know if there is any other document that describe what I have to do to control the application exe with an external VI? Can you be a little more specific... what doesn't work? There's a few tips: If you can't open the application reference: -make sure the port number you select is available. and that your firewall (if enabled) is not blocking it. If you can't open the vi reference: -make sure your using the correct path/name. If you can't access the control reference: -make sure your using the label name (if the control is located -if the control you're after is inside a cluster or on a tab you'll have dig through chain. I'm not aware of any specific guidance on this outside of LV help. If you post your sample app , INI, and test VI I'll step you through it. Unfortunately the example I posted is gone and I can't upload from work. (If I find it, I'll post it again this evening.) ~Dan Link to comment
Please sign in to comment
Sign In Now
