buhrz Posted July 15, 2010 Report Posted July 15, 2010 Hi all I get this error Error -200288 occurred at DAQmx Write Possible reason(s): Attempted to write a sample beyond the final sample generated. The generation has stopped, therefore the sample specified by the combination of position and offset will never be available. Specify a position and offset which selects a sample up to, but not beyond, the final sample generated. The final sample generated can be determined by querying the total samples generated after a generation has stopped. Attempted to Write Sample: 5001 Property: RelativeTo Corresponding Value: Current Write Position Property: Offset Corresponding Value: 0 Task Name: Output whe i write the second time a wafeform to the analog output How can I fix this problem ? Any help Jürgen PS LabVIEW 2009 SP1 Quote
crelf Posted July 15, 2010 Report Posted July 15, 2010 Please upload your code (or some code that shows the issue) so we can take a look. Quote
