NOISE PROBLEM for NI DAQ 6015E
Vincent88
Hi, i'm Vincent
i'm working at a simple progect wich must to acquire a signal from a microphone with the NI DAQPAD 6015.
In Labwiev i had built a procedure that filters and amplifies the signal acquired. My problem is that when i go to
do the fast fourier transformate i notice the noise at the high frequencies that are stronger than the signal acquired, i notice the noise
also when i go to listen the file in wich i had save my acquisition.I had already take some precautions, like to shield wire and microphone utilizing a Faraday's cage but,
although the noise is smaller than before, it's still too bigger than the signal.
Other information:
samples frequency: 44100
acquisition tipe: continuos
samples to read: 250000
Anybody have any idea about this problem?
Thanks for the answer
