COsiecki Posted October 8, 2010 Report Share Posted October 8, 2010 I am trying to map hardware that is currently in use. Is there a daqMX property that will let you know if the device or physical channel is reserved? I know that if you try to run two tasks on the same hardware you get error 50103 and you could capture that, but I'd like to not need to create and run a task on every channel in my system. Another option would be to assume that nothing else is running (probably a fair assumption on our systems) and then flag them as "in use" in my software. Has anyone come up with any other methods for this type of thing if there isn't something in daqMX? Quote Link to comment
