mike5 Posted October 22, 2010 Report Share Posted October 22, 2010 Hi, I would like to dynamically load classes on a real-time PXI. The process is defined here, and I guess it works even on real-time (haven't tried it yet). The current problem is making sure that the class and all the required VIs are actually deployed to the device. With static loading LV loads everything it needs on the RT device, but if I load the classes dynamically, what is the best way to ensure that the required classes will actually make it to the device. Thanks in advance, Mike Quote Link to comment
