Translation of TS Sequence Editor
Zyl
Hi everybody !
Currently developing an application embedding TS interface (ActiveX) in several languages, I'm facing a problem with the TS UI strings : they are only available in English !!!
If you want to display your TS interface in other languages, you have to translate INI files that are placed in "C:\Program Files\National Instruments\TestStand 4.2.1\Components\Language\<Language>"...
That's a lot of work !!
So the idea is, maybe, you guys have already done this work for several languages... Why not sharing it here ?
PS: As soon as my French translation is finished, I'll post it here !
  • 2 weeks later...
Chose promise, chose due !
Voici une version (non complete) qui permet d'avoir la plupart des strings d'interface en Francais. Si quelqu'un se sent des les completer, qu'il | elle n'hésite pas à les faire partager...
Here they are !
All strings are not translated but most of the interface strings are in French... If somebody wants to complete them, then share the update !
Francais.zip
