jimc1041 Posted November 18, 2010 Report Posted November 18, 2010 I am in the process of converting an old test application that uses Legacy NI-DAQ driver function in LabVIEW to use an equivalent set of DAQmx driver functions. The app uses a PCI-6024E card and synchronizes the AI and AO calls with hard ware signals. It also uses the old DAQ-occurances to time the AI read and AO write functions. I'm not sure what the DAQmx equivalent of the old DAQ-occurance functions are. I have posted on the NI forums showing BD segments for the main DAQ VI. [cross post --- http://forums.ni.com/t5/Multifunction-DAQ/Update-Legacy-DAQ-sync-d-AI-AO-to-DAQmx-equivalent/td-p/1314635] Any help would be appreciated. Thanks, Jim C Quote
crelf Posted November 18, 2010 Report Posted November 18, 2010 There's something wrong with the link - I get "Page Not Found" back from NI's server. Quote
asbo Posted November 18, 2010 Report Posted November 18, 2010 There's something wrong with the link - I get "Page Not Found" back from NI's server. Remove the trailing square bracket: http://forums.ni.com/t5/Multifunction-DAQ/Update-Legacy-DAQ-sync-d-AI-AO-to-DAQmx-equivalent/td-p/1314635 Quote
