topper99 Posted August 9, 2004 Report Posted August 9, 2004 I'm very new to using Labview 7.1. What i need to do is collect the coordinates from a serial mouse into labview and then plot these coords onto a graph. My ultimate aim is to then be able to determine a mathematical equation which would then determine when the coordinates of two mice held at a fixed distance from each other, and on the same axis, change when they are rotated. For the moment obtaining the coordinates from the serial ports is the problem. I have configured a port connection using the examples listed within labview 7.1 but the values that i am obtaining are all euro signs. Is there anyone out there who could suggest how i might be able to decrypt the info that i seem to be getting and process it into something more useful? Thanks, Topper99 Quote
didierj Posted August 9, 2004 Report Posted August 9, 2004 Hi, In the Palette menu under "Advanced>Input Device Control" you find the VI's Initialize Mouse.vi and Acquire Input Data.vi. With these VI's you can get the mouse position of your actual mouse. Download File:post-253-1092046089.bmp To make a second mouse work on your computer, I don't know if possible - never tried. If it works, then try to "hack" the Initialize Mouse.vi: change the constant from 0 to 1. Download File:post-253-1092046391.bmp Didier Quote
topper99 Posted August 9, 2004 Author Report Posted August 9, 2004 Cheers Didier. Iv now managed to get that sorted. As you say there is a problem with connecting two mice into the pc and distinguishing them from one another. I might have to "simulate" another mice with some user defined control boxes. Thanks again. Topper99 Hi,In the Palette menu under "Advanced>Input Device Control" you find the VI's Initialize Mouse.vi and Acquire Input Data.vi. With these VI's you can get the mouse position of your actual mouse. Download File:post-253-1092046089.bmp To make a second mouse work on your computer, I don't know if possible - never tried. If it works, then try to "hack" the Initialize Mouse.vi: change the constant from 0 to 1. Download File:post-253-1092046391.bmp Didier 1340[/snapback] Quote
