execution error
sydney
I have linux 2010 PD systems installed on two CentOS 5.3 OS systems. On one system I have a fairly large project that compiles and run from the development environment with no problems, but when I build the executable file and run it I get error loading VI where Get Text Rect.vi, Error Code Database.vi and NI-FileType.lvlib. Thjis same file does run OK with no such errors when run on the other CentOS machine. I looked at /usr/local/natinst directory to see if the library file was there but I could not see anything different between the two machines. My next thought was to completely uninstall the LabVIEW PDS and reinstall it. Any other ideas on this problem?
