trymmelumm Posted April 8, 2011 Report Posted April 8, 2011 Hey I am new with labview, and I have some problem getting started with my project. I am trying to speed controll a treadmill using a camera that detects the runner. the runnert posistion decide if the treadmill should accelerate or de accelerate. the problem i have so far is the image processing. I have two cameras. one PS3Eye camera, and one vivotek Ip camera. none of them are working with NI Vision Assistant. (ni imaq usb drivers dont work with PS3Eye cam, and i cant find anyway to connect to the Vivotek Ip camera). So I used a activex controller to get stream from the Ip camera. The problem is that i now cant find any way to process the image. do anyone now if there is a way to process the videostream when using a activx controller? Quote
Corny Posted May 14, 2011 Report Posted May 14, 2011 Have you tried the ActiveX from Vivotek? I've currently run into some issues as it looks like my ActiveX from Vivotek not even wants to connect to the camera. I'll let you know if I find out more, however, please post if you find a solution as well Quote
