JMak Posted April 12, 2011 Report Posted April 12, 2011 Hi, This is a bit of a long-shot but I need help with the LabVIEW driver for the Jenoptik ProgRes Firewire cameras. I have installed the driver, I have found some .vi's in the help folder, but I can't get it to detect the camera. When I send commands to capture images, the LED on the camera appears as if it is working (capturing when the LED flashes). However, the camera is not detected in Vision Assistant, and I can't see any images - they just appear black. The vi appears to use ActiveX commands over firewire. When I run the vi to find cameras, I get "an unknown error has occurred in [the vi I am running]". When I use certain settings such as longer exposure times in the LabMEX vi LabMEX.vi, the program crashes and quits or freezes the screen. I'm not sure what to do... Any thoughts? VI Tree VI Tree.vi seems to show all the commands. Initialize Initialize.vi is supposed to find the camera. If you can help, it is much appreciated. Quote
Juavito Juavito Posted January 22, 2017 Report Posted January 22, 2017 could you send me all files, please? Quote
