ress Posted September 7, 2004 Report Posted September 7, 2004 I use Labview to read two quadrature encoder outputs and I use the two counters of 6024E for this. I can read the encoders continuously. I also want to send an analog output with a period of 30 miliseconds while the reading of encoders is continuouing at the background. How can I do this. I searched the NI discussion forums and found that my device have only 1 DMA channel. Is it possible to overcome the problem using interrupt??(set device information.vi) Is there any example code about this problem? Thanks a lot.." Quote
