Palette File API in LV2010
I've just discovered something slightly curious about the palette file API vis in newer versions of LabVIEW - they do not appear to the same thing as editing the palettes by hand.
In 2010, add a .xnode file to the palette manually and it will show the icon of the help ability vi and the name of .xnode file as the text. Now using the palette file API vis, read the same palette file and then write it out again and refresh. Now the palette files show "Help" as the text and not the XNode's name.... (at least for meon 64 bit 2010). Ho hum. I guess the palette file format must have been updated and the API vis haven't.
