CLD Sample test comments
Hi All,
I'm planning to take CLD next month and tried out a few examples from the sample questions available on the NI website.
I'm trying to create a template which can be used for all timing related problems, and have come up with this solution. Can anybody go through this code and give your comments?
I have attached the Question and code for the sprinkler controller example.
awaiting comments,
kathir
100927-01.pdf
Sprinkler_For_Forum.zip
  • The main startup vi should be at the top level of the hierarchy.
  • I personally hate auto-populating folders but that should definately not have any impact on your score.
  • Some of your subvis do not have documentation properties. Make sure every one does including the main vi. That was the only point I lost on documentation.
  • Some of your controls do not have tip-strips.
  • A few backwards wires
  • You should put labels on the shift register wires.
One way to ensure you got all the documentation properties is to use view/hierarchy and mouse over the subvis. You can right click from the hierarchy view to open the vi properties. A better way to make sure is to immediately fill it the documentation when you create the vi. Same for tip-strips on controls.
Thanks for the reply.
I will keep in mind the points you told, in the CLD exam.
But can u comment on the architecture i chose for this sample test. I'm planing on using this as a template for all time related questions.
For the CLD you can use whatever reasonable architecture you are comfortable with as long as it is a state machine type of architecture. No stacked sequence structures with a dozen unlabeled sequence locals!
I don't have access to LabVIEW at the moment but as I recall you have two loops and each has it's own event structure and you communicate between the two with user events. I think that should be fine but the architecture that is probably more preferable, or at least more common, is the producer/consumer. You have one loop with an event structure that sends messages to the second using a queue. That second loop sends messages back to the first loop using user events.
If you want to get some attention here on Lava just use a class for something simple like timing and make the claim that your solution is object oriented :D
Have you tried asking for feedback on the NI forums?
