[CR] Hyper Terminal
index.php?app=downloads&module=display&section=screenshot&id=172
Submitter: Prabhakant Patil
Submitted: 24 May 2011
File Updated: 05 Jul 2012
Category: Hardware
LabVIEW Version: 2010
License Type: BSD (Most common)
Hyper Terminal_LV2010 v1.1.0
Copyright © 2012, Prabhakant Patil
All rights reserved.
Author: Prabhakant Patil
LAVA Name: Prabhakant Patil
Contact Info: Contact via PM on lavag.org
LabVIEW Versions:2010
Dependencies:
Required NI VISA
Description:
Hyper Terminal is a program that you can use to connect to other computers, devices and host computers.
Hyper Terminal has capabilities beyond making connections to other computers and devices. It can, for example, transfer large files from a computer onto your portable computer using a serial port rather than requiring you to set up your portable computer on a network. It can help debug source code from a remote terminal. It can also communicate with many older, character-based computers.
Hyper Terminal records the messages passed to and from the computer on the other end of your connection. It can therefore serve as a valuable troubleshooting tool when setting up and using your serial port. To make sure that your device is connected properly or to view your device settings, you can send commands through Hyper Terminal and check the results. Hyper Terminal also has scroll functionality that enables you to view received text that has scrolled off the screen
Installation and instructions:
Control Name Description
  • Connect / Disconnect: Clicking on this button, selected com port will connect or disconnect.
  • Send File: Clicking on this button, file section window will open. User can select the file which supposed to send.
  • Log file: Clicking on this button, User can log the data to the selected file.
  • Clear Screen: Clicking on this button, the display screen will be cleared
  • Autowrap: This will wrap the text
  • Local Echo: This will generate an echo
  • CR=> CR/LF: Send End character
  • Auto scroll: Will scroll display automatically
  • Display Style: Select the display style, like Normal, Hex code display
  • Exit: Clicking on this button, application will exit.
Examples:
Known Issues:
Acknowledgements:
Version History: v1.1.0: Initial release of the code.
License: BSD
Distributed under the Creative Commons Attribution 3.0 (http://creativecommons.org/about/licenses)
See link for a full description of the license.
Support:
If you have any problems with this code or want to suggest features:
please go to lavag.org and Navigate to LAVA > Resources > Code Repository (Certified) and
search for the "Hyper Terminal_LV2010" support page.
Distribution:
This code was downloaded from the LAVA Code Repository found at lavag.org
  • 1 month later...
