Anytime I try to build an executable, I get an error8.
Here is a copy of the message:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 8 occurred at Copy in AB_Engine_Copy_Error_Files.vi->AB_Application.lvclass:Copy_Error_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_EXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW: File permission error. You do not have the correct permissions for the file.
NI-488: DMA hardware error detected.
C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\2010\errors\frchconvlib-errors.txt
If I navigate to frchconvlib-errors.txt, I find that is is marked as read only. If I uncheck the read only box, the build is successful. If I try to run build again, I get the same error and have to uncheck read only again. It does not matter if I am building an app that included the Frame-channel conversion library or not, I always get the error.
I'm running Labview 2010 on a WinXP laptop. Any ideads?
Do you have the build chekc box that includes custom error codes checked? I'm not sure if you need any of the custom error codes installed on your development PC - unchecking that might be a workaround. No idea on hte root cause though...
Starting with LabVIEW 2010, build specifications will copy any errors codes to the run-time engine location by default. This setting is located in the Advanced page. If you do not need to copy the error code files, you can uncheck this option.
Thanks guys, I went to the advanced tab and unchecked "Copy error code files" and it will work for now but I know eventually I will need to use that option.
