tims Posted September 22, 2004 Report Share Posted September 22, 2004 Here is a tool, that i have just created, that lets a developer, to externally control front panels that are imbedded in an executable. I thought other developers, who use lots of executables, would find this useful too. Some Basic Instructions: - To be able to display a VI's front panel, the application builder has to be forced, in the applications builder's 'VI Settings', to leave it in. - 'Open' Button This displays a dialog box which you use to select the actual executable you want to access. - If the executable is already running and the correct Port is already open, when selected, the program immediately displays the exes displayable VI's. - It the executable is not running, a dialog box is displayed that says it is waiting for the executable to be opened. The user can either open the executable manually or use the 'Open App' button. - There are more combinations handled but i am not going to describe them all there. - 'Refresh' Button If VI's are loaded dynamically, the user will have to use the refresh button to update the displayed list. - The rest of the UI is self explanatory. Some Notes: - This program modifies , VI Server port setting and host address, in the executables ini file, if these settings are important or you don't want this port left open keep a copy of the original ini file so it can be replaced. - I have included the executable, which is compiled in LV6.1, i have never tested its use on a LV7.x executable and so i am including the code as well. - To use the LV code it needs OpenG's file library. If you have any questions let me know. Tim Download File:post-535-1095820069.zip Quote Link to comment
Mike Ashe Posted December 22, 2004 Report Share Posted December 22, 2004 Here is a tool, that i have just created, that lets a developer, to externally control front panels that are imbedded in an executable. I thought other developers, who use lots of executables, would find this useful too....snip... Tim 1858[/snapback] Thanks Tim, nifty tool. Do you have any updates planned? Quote Link to comment
