Ignore missing friends in the build
Hi all,
I have a class that has some methods that only need to be called by unit tests. I have defined these methods to be in the community scope, and the unit tests are class friends. So far, so good.
In another project I have a copy of the library folder (svn:externals), but the unit tests are not needed. If I run a build in this project, I get an error saying that the "unit test" vi is missing, since it is referenced by the lvclass file. And the build fails.
Is there a way ti make this problem go away, since the class friends are really not needed for the library in question. Nor are they needed by the library consumers. Right?
Thanks in advance and best regards, Mike
