Tab control with ActiveX container
m3nth
Just thought I'd post this for general knowledge... I ran into it awhile ago and NI knows it exists.
If:
  • There's an ActiveX container on a tab control
  • The tab with the ActiveX container is selected (ie, the ActiveX container is visible)
  • The Tab control visibility is set from True to False
...then the ActiveX container will remain visible instead of disappearing with the tab control.
If:
  • The tab control visibility is then set from False back to True
  • The user changes to a different tab (ie, the ActiveX container is not visible)
  • The tab control visibility is set from True to False
...then the ActiveX container will remain not visible.
Possible workarounds include:
  • Programmatically changing the active tab to a different page than the one with the ActiveX container before setting the tab visibility to false
  • Setting the ActiveX container visibility to True/False in conjunction with the Tab control visibility
