Change Mouse cursor
majestic12
Hello,
Is there a way to change the default mouse cursor in LabVIEW 6.1. We have someone here that has to use our software that has trouble using the mouse, and needs a bigger cursor, but I can't seem to find anything in the help or online that tells me how to change it. Thanks in advance.
Mike
Hi Mike,
You can change the mouse cursor in general. In Windows go to the control panel (Start>Settings>Control Panel) and change the mouse settings. There you can select/change the mouse appearance.
Changing the mouse just for LV is probably not possible, except if you use API-functions.
Didier
