Fritz_85 Posted August 29, 2011 Report Share Posted August 29, 2011 Hi Everybody! Right now I am working on a project where I have to work with the measurment amplifier QuantumX MX840 from the company HBM. I have been trying to communicate with the QuantumX by LabVIEW. However, there is always showing up the Error 7. I have attached the SubVI which Ive been trying to work with and also two more pics, one of the block diagram and one of the panel. In the pic of the blockdiagram I marked the invoke node QXSystem red, cause thats where the Error comes from. Maybe somebody who already has had experience with the QuantumX MX840 can help me with this problem and tell me why this error is occuring. I would really appreciate! Sincerely Fritz QX_Init.vi Quote Link to comment
asbo Posted August 29, 2011 Report Share Posted August 29, 2011 Error 7 is: "File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer." Try reinstalling your .NET assembly. Quote Link to comment
Fritz_85 Posted August 29, 2011 Author Report Share Posted August 29, 2011 Thanks for answering! But how do I reinstall the .NET assembly in LabVIEW? Quote Link to comment
asbo Posted August 29, 2011 Report Share Posted August 29, 2011 You don't reinstall it *in LabVIEW*, it's a system-wide install. I assume you got an installer from the manufacturer. Use that to uninstall and reinstall the assembly. Quote Link to comment
