Wouter Posted September 3, 2011 Report Posted September 3, 2011 VI Name: Temperature conversion Total VIs: 31 Description: This VI converts a temperature to one of the existing temperature scalings. One could use the convert unit VI from the pallet. But firstly expression nodes prevent VI's from being inlined also it does not support all temperature scalings. Note: Blockdiagram: - Code: Conversion temperature.zip What are you thoughts on this VI? Would you like to see such a function in OpenG? Can you optimize the code? In which package should it be included? Should it be rejected? Quote
